Knowledge Base Article
Error(19063): Found an IOPLL cascade chain of three or more IOPLLs. The first three IOPLLs found are listed below.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.1 and earlier, you may see this error when your design contains IOPLL to IOPLL clock connections through the mgmt_clk input port.
IOPLL to IOPLL clock connections through the mgmt_clk input port should not be considered as PLL cascading.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Pro Edition Software version 21.3
Download and install Patch 0.36 from the appropriate link below.
Download patch Intel® Quartus® Prime Pro Edition 21.3 Patch 0.36 for Windows (.exe)
Download patch Intel® Quartus® Prime Pro Edition 21.3 Patch 0.36 for Linux (.run)
Download the Readme for Intel® Quartus® Prime Pro Edition 21.3 Patch 0.36  (.txt)
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0
