Knowledge Base Article
Error(18090): External memory and PHYLite interfaces must share a common clock and reset signals when constrained to the same I/O column.
Description
Due to a problem in the Intel® Quartus® Prime software version 19.2 or earlier, you may see the fitter error message when you aren't sharing the same clock and reset signals across multiple Intel Arria® 10 EMIF IPs in the same I/O column. This message is incorrect, and you can follow the guidelines described in the Intel® Arria® 10 EMIF IP User Guide. To place multiple interfaces in the same I/O column, you must ensure that each interface's global reset signals (global_reset_n) come from the same input pin or signal.
Resolution
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
