Knowledge Base Article
Error(15360): DSP block WYSIWYG primitive "u0|a10_native_fixed_point_dsp_0|twentynm_mac_component" has unconnected port ACLR[0] -- port must be connected because corresponding register is used
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 20.3 and later, you may see this error when you are using the Arria® 10 Native Fixed Point DSP IP. The error happens because the user is enabling registers for "az" and "bz" but not using the "az" and "bz" ports.
Resolution
To avoid this error, disable the registers for "az" and "bz" in Data "z" Configuration if you are not using "az" and "bz" ports.
This error is planned to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 2.0
