Knowledge Base Article
Error(14566): The Fitter cannot place x periphery component(s) due to conflicts with existing constraints (x IOPLL(s)).
Description
Due to the Triple-Speed Ethernet Intel® FPGA IP restriction with the option "LVDS" as "Transceiver type," IOPLLs can't be merged.
You may see this error in the Intel® Quartus® Prime software when you initiate multiple Triple-Speed Ethernet Intel® FPGA IP with option "LVDS" as "Transceiver type" in a single I/O bank for the Intel® Arria® 10, Intel® Cyclone® 10 GX or Intel® Stratix® 10 L-Tile/H-Tile device.
Resolution
To avoid this error, follow the steps below:
  1. Generate the Triple-Speed Ethernet Intel® FPGA IP with the option "None" as "Transceiver type."
  2. Generate the LVDS SERDES Intel® FPGA IP with multiple channels.
  3. Connect two IPs manually.
Updated 11 months ago
Version 3.0
