Knowledge Base Article
Error(13224): Verilog HDL or VHDL error at altera_pcie_s10_hptxs_tx.sv(<your line number>): index <your index> is out of range [<your range>] for address
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 17.1 and earlier, you will see this error with the Avalon®-MM Stratix® 10 Hard IP for PCI Express* if you do the following:
  • Select "Enable high-performance bursting Avalon-MM slave interface (HPTXS)"
  • And select "Enable mapping (HPTXS)"
  • AND select one of the first two choices
    • 1 page - 0 bits
    • 2 pages - 1 bit
Resolution
To work around this issue, choose one of the remaining 8-page mapping selections.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 17.1.1.
Updated 1 year ago
Version 2.0
