Knowledge Base Article
Error May Occur When Simulating VHDL Designs With MMR Enabled Using VCS-MX
Description
A segmentation fault may occur when simulating an Arria 10 EMIF IP in VHDL with MMR enabled, using Synopsys VCS-MX.
Resolution
The workaround for this issue is as follows:
- Run vhdlan without the -xlrm option.
- Run vcs with the -xlrm option.
This problem will be fixed in a future version.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
