Knowledge Base Article
ERROR: iossmwr_cal_bf_cpu_cpu_test_bench/ihp_read is 'x'
Description
You may see the error message from Questasim*/Modelsim* during simulation when you instantiate the Agilex™ 7 FPGA M-Series DDR5 EMIF IP in your design.
Resolution
Workaround is to use the set USER_DEFINED_COMPILE_OPTIONS "-O0" option to compile the design.
Updated 4 months ago
