Knowledge Base Article
Error (12077): Node instance "altera_mult_add_rtl2" instantiated with unknown parameter "ACCUM_SLOAD_PIPELINE_SCLR"
Description
Due to a problem with the Cyclone® V FPGA ALTMULT_COMPLEX IP in the Intel® Quartus® Prime Standard Edition Software version 17.0, you might see the error above during compilation if the IP variation file type is VHDL.
Resolution
To work around this issue, use the Verilog IP variation file type.
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition Software version 18.0.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
