Knowledge Base Article
Does GTS Serial Lite IV FPGA IP supports 0.0 MHz system/HVIO PLL frequency?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, you will observe that the GTS Serial Lite IV FPGA IP GUI system/HVIO PLL frequency parameter in the dropdown list contains 0.0 MHz, which is not a valid option.
Resolution
To work around the above problem, you should not select the "0.0" option from the dropdown list.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
Updated 4 months ago
Version 4.0
