Knowledge Base Article
Compiler error: "If ECC is enabled, Scrubbing should also be enabled."
Description
The preloader generator disables SDRAM ECC bit initialization by default. If the SDRAM ECC is enabled, the following compiler error appears:
If ECC is enabled, Scrubbing should also be enabled.Resolution
If the SDRAM ECC is enabled, enable SDRAM ECC bit initialization in the preloader generator.
Updated 3 months ago
