Knowledge Base Article
cc1plus.exe: out of memory allocating 65536 bytes
Description
This error may be seen when compiling large software projects on Windows platforms.   cc1plus.exe is a 32bit Windows application and has access to 2GB of memory on Windows.
Resolution
To work around this problem, Windows can be configured to allow 32bit applications access to a 3GB address space.
1. Enable 3GB address space for 32bit applications on Windows:
 From Windows command prompt run:  bcdedit /set IncreaseUserVa 3072
2. Allow cc1plus.exe to use the larger address space
 From Windows command prompt run: editbin /LARGEADDRESSAWARE "<path>/cc1plus.exe“
This problem is scheduled to be fixed in a future release of the SoC EDS Software.
Updated 10 months ago
Version 2.0
