Knowledge Base Article
Can the Intel® Stratix® 10 HBM2 efficiency monitor test pattern run in an infinite loop?
Description
The efficiency monitor test pattern is implemented to run only one loop regardless of the traffic generator parameter setting.
Resolution
To make the test pattern run continuously, toggle the wmcrst_n_in signal after the traffic_gen_pass signal is asserted high.
Updated 11 months ago
Version 3.0
