Knowledge Base Article
Can the Intel® Quartus® Prime Pro Edition Software create a .rpd file for updating a single image without the start address block in remote system update in the Intel Arria® 10 devices?
Description
No. When the Intel® Quartus® Prime Pro Edition Software creates a .rpd file in the Intel Arria® 10, the start address block is always included in the first 32-byte area.
Resolution
Use one of the following two workarounds when updating a single image in a remote system update in the Intel® Arria® 10,
- Skip data bytes from 0x00000000 to 0x0000001F to program a .rpd file
- Modify a .rpd file and remove data bytes from 0x00000000 to 0x0000001F and program the modified .rpd file
Note that when updating a factory image, a .rpd file with a start address block is required. This is because a start address block is erased together with the factory design image in the sector erase operation before the programming operation.
Updated 1 month ago
