Knowledge Base Article
Can the 128-bit Avalon® memory-mapped Txs agent interface of the Hard IP for PCI Express handle read/write request with ByteEnable=0x01 ?
Description
Due to a problem in the Quartus® II software version 13.1 and earlier, the 128-bit Avalon® memory mapped Txs agent interface of the Hard IP for PCI Express cannot generate a correct PCI Express TLP packet when the ByteEnable = 0x01, 0x03, or 0x7 at Avalon memory mapped interface.
Avalon memory mapped bridges operate correctly with a burst count = 1 and the following byte enables (DW Byte Enable)
16'hF000
16'h0F00
16'h00F0
16'h000F
16'hFF00
16'h0FF0
16'h00FF
16'hFFF0
16'h0FFF
16'hFFFF
Resolution
To work around this problem, use a 64 bit Avalon memory mapped Txs agent interface, or set ByteEnable to more than 0x07 (set 4 byte enable or more) with a 128-bit Avalon memory mapped Txs agent interface.
There is currently no plan to fix this problem.
Updated 2 months ago
Version 2.0
