Knowledge Base Article
Can I use generic parameters with transceiver MegaWizard generated files to create multiple transceiver MIF file variations for Altera transceivers?
Description
No, you cannot use generic parameters with transceiver MegaWizard™ generated files to create multiple transceiver MIF file variations for Altera® transceivers.
If you require multiple MIF files for different transceiver configurations, you must instantiate a separate transceiver MegaWizard generated file for each required variation.
Updated 1 year ago
