Knowledge Base Article
​​​​​​​Why do I see intermittent RX read data errors when the Agilex™ 5 MIPI D-PHY FPGA IP design example is operating at a low data rate of 150Mbps ?
Description
Due to a problem in the Quartus® Prime Pro Edition Software versions 24.1 and 24.2, you will encounter intermittent RX read data errors when testing on hardware with the Agilex™ 5 FPGA MIPI D-PHY FPGA IP design example operating at a low data rate of 150 Mbps.
Resolution
To work around this problem in the Quartus® Prime Pro Edition software version 24.2, set the Agilex™ 5 FPGA MIPI D-PHY IP GUI TX timing param “TX_HS_ZERO” to 30,  regenerate and recompile the design to ensure the change takes effect.
Currently, no workaround is available when using the Quartus® Prime Pro Edition Software version 24.1.
This problem is fixed beginning with version 24.3 of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
