15 years agowrite .bmp on sd card by ip sd card controller
Hi all!
I'm doing a project about " write.bmp from camera to sd card by use de2 board" i use IP Controller Sd card and I have some problem about my project: - I interface DE2 board with Camera. it's Ok - image is stored on Sdram and i use Sram buffer to display on Vga. it's Ok -But when i write .bmp to on Sdcard. it's not Ok. I check sdcard. I see filesize of image, but i can't open that image.( maybe i write wrongly) Give me some help, please..8 Replies
my code:
//================# include <io.h># include <system.h># include <stdio.h># include "gui.h"# include "altera_up_sd_card_avalon_interface.h" struct image images[MAX_NUM_IMAGES]; struct image *current_image; struct image *prev_image = NULL; int num_images = 0; int current_image_num = 0; short int file_handle1; char name1[] = "filexx.bmp"; // send image on Sdram to Sram_frame_buffer void send_image(int direction) { current_image = (direction == 2) ? current_image->next : current_image->prev; printf("current image: %d\n", current_image->image_num); int i = current_image->image_num; printf("sending image\n"); unsigned char byte_r, byte_g, byte_b; int pixel; int x, y; int x_start = 0; int x_end = IMG_X_SIZE; int x_inc = 1; for (x = x_start; x < x_end ; x += x_inc) { for(y = 0; y < IMG_Y_SIZE; y += 1) { // send request IOWR_16DIRECT(TV_TO_VGA_0_BASE, 16, 1); // set requested x and y positions IOWR_16DIRECT(TV_TO_VGA_0_BASE, 10, x); IOWR_16DIRECT(TV_TO_VGA_0_BASE, 12, y); // get pixel from memory byte_r = saved_images[0][y][x];byte_g = saved_images[1][y][x]; byte_b = saved_images[i][2][y][x]; if (num_images == 0) pixel = 0; else pixel = ((byte_r >> 3) << 11) | ((byte_g >> 2) << 5) |((byte_b >> 3) << 0); // send pixel IOWR_16DIRECT(TV_TO_VGA_0_BASE, 14, pixel); // reset request IOWR_16DIRECT(TV_TO_VGA_0_BASE, 16, 0); } } printf("sent\n"); }
void save_image() //== store image on sdram
{ num_images++; unsigned char byte_r, byte_g, byte_b; int pixel; int x, y; // find next free slot int i; for (i = 0; i < MAX_NUM_IMAGES; i++) { if (!images.is_taken){
current_image = &images; break; } } if (prev_image == NULL) { current_image->prev = current_image; current_image->next = current_image; } else if (num_images == 2) { prev_image->prev = current_image; prev_image->next = current_image; current_image->prev = prev_image; current_image->next = prev_image; } else if (num_images >= 3) { current_image->prev = prev_image; current_image->next = prev_image->next; prev_image->next->prev = current_image; prev_image->next = current_image; } current_image->is_taken = 1; current_image->image_num = i; prev_image = current_image; printf("saving image: %d/%d\n", i, num_images); for (y = 0; y < IMG_Y_SIZE; y += 1) { for(x = 0; x < IMG_X_SIZE; x += 1) { // send request IOWR_16DIRECT(TV_TO_VGA_0_BASE, 4, 1); // set requested x and y positions IOWR_16DIRECT(TV_TO_VGA_0_BASE, 0, x); IOWR_16DIRECT(TV_TO_VGA_0_BASE, 2, y); // get pixel data pixel = IORD_16DIRECT(TV_TO_VGA_0_BASE, 6); // enter pixel data into image matrix byte_r = (unsigned char) (((pixel >> 11) & 0x1F) << 3); byte_g = (unsigned char) (((pixel >> 5) & 0x3F) << 2); byte_b = (unsigned char) (((pixel >> 0) & 0x1F) << 3); // save pixel saved_images[0][y][x] = byte_r;
saved_images[1][y][x] = byte_g; saved_images[i][2][y][x] = byte_b; } } printf("saved\n"); printf("number of images: %d\n", num_images); }
my code:
//==========================write image on sd card void write_image(int number) { char i = number; char h = 0; bool create, hum ; int x, y,j, c; alt_up_sd_card_dev *device_reference = NULL; int connected = 0; device_reference = alt_up_sd_card_open_dev("/dev/SD_Card_0"); if (device_reference != NULL) { if ((connected == 0) && (alt_up_sd_card_is_Present())) { printf("Card connected.\n"); if (alt_up_sd_card_is_FAT16()) { printf("FAT16 file system detected.\n"); } else { printf("Unknown file system.\n"); } connected = 1; } else if ((connected == 1) && (alt_up_sd_card_is_Present() == false)) { printf("Card disconnected.\n"); connected = 0; } } - Altera_Forum
//==============define header==============
unsigned char BITMAP_HEADER[] = { 0x42, 0x4D, 0xB6, 0x91, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x50, 0x01, 0x00, 0x00, 0xE8, 0x00, 0x00, 0x00, 0x01, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0xAD, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; printf("Bitmap header size is %d\n", (int) sizeof(BITMAP_HEADER)); int file_size = (IMG_X_SIZE1*IMG_Y_SIZE1) * 3 + sizeof(BITMAP_HEADER); // write byte 0 (LSB) BITMAP_HEADER[FILE_SIZE_OFFSET+0] = (file_size >> 0) & 0xFF; // write byte 1 BITMAP_HEADER[FILE_SIZE_OFFSET+1] = (file_size >> 8) & 0xFF; // write byte 2 BITMAP_HEADER[FILE_SIZE_OFFSET+2] = (file_size >> 16) & 0xFF; // write byte 3 (MSB) BITMAP_HEADER[FILE_SIZE_OFFSET+3] = (file_size >> 24) & 0xFF; printf("Bitmap file size: %02X %02X %02X %02X\n", BITMAP_HEADER[FILE_SIZE_OFFSET+0], BITMAP_HEADER[FILE_SIZE_OFFSET+1], BITMAP_HEADER[FILE_SIZE_OFFSET+2], BITMAP_HEADER[FILE_SIZE_OFFSET+3] ); // write byte 0 (LSB) BITMAP_HEADER[PIXEL_WIDTH_OFFSET+0] = (unsigned char)((IMG_X_SIZE1 >> 0) & 0xFF); // write byte 1 BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1] = (unsigned char)((IMG_X_SIZE1 >> 8) & 0xFF); // write byte 2 BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2] = (unsigned char)((IMG_X_SIZE1 >> 16) & 0xFF); // write byte 3 (MSB) BITMAP_HEADER[PIXEL_WIDTH_OFFSET+3] = (unsigned char)((IMG_X_SIZE1 >> 24) & 0xFF); printf("Bitmap width: %02X %02X %02X %02X\n", BITMAP_HEADER[PIXEL_WIDTH_OFFSET], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+3] ); - Altera_Forum
BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+0] = (unsigned char)((IMG_Y_SIZE1 >> 0) & 0xFF); // write byte 1 BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+1] = (unsigned char)((IMG_Y_SIZE1 >> 8) & 0xFF); // write byte 2 BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+2] = (unsigned char)((IMG_Y_SIZE1 >> 16) & 0xFF); // write byte 3 (MSB) BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+3] = (unsigned char)((IMG_Y_SIZE1 >> 24) & 0xFF); printf("Bitmap height: %02X %02X %02X %02X\n", BITMAP_HEADER[PIXEL_HEIGHT_OFFSET], BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+1], BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+2], BITMAP_HEADER[PIXEL_HEIGHT_OFFSET+3] ); - Altera_Forum
//========open file to write bitmap=====
name1[4] = h/10 +48; name1[5] = h%10 +48; file_handle1 = alt_up_sd_card_fopen(name1, create); if (file_handle1 == -1) printf("file could not be open.\n"); else if ((file_handle1 == -2)) printf("file be already.\n"); else printf("file be open.\n"); if (create == true) printf("file be create .\n"); //=========write header============= for (j=0; j<54; i++) { alt_up_sd_card_write( file_handle1, BITMAP_HEADER[j]); printf("write header.\n"); } //============write data================= for (y = 0; y < IMG_Y_SIZE1; y += 1) { printf("."); for(x = 0; x < IMG_X_SIZE1; ++x) { for (c = 2; c >= 0; c--) { alt_up_sd_card_write( file_handle1, saved_images[i][c][y][x]); //printf("file be write .\n"); } } } printf("\nDone!\n"); hum = alt_up_sd_card_fclose(file_handle1); if (hum == true) printf("file be close.\n"); if (h <100) h++; return 0; } - Altera_Forum
Because, First I post document on forum, so i have some mistakes..
I have to post my code more once. hic. Ok..Please, You help me? Thanks so much - Altera_Forum
could you please provide the link or the program files you have interfaced the sdcard for storage. I am working on the same project now.
