15 years agowrite .bmp on sd card by ip sd card controller
Hi all! I'm doing a project about " write.bmp from camera to sd card by use de2 board" i use IP Controller Sd card and I have some problem about my project: - I interface DE2 board with Camera. ...
15 years ago//==============define header==============
unsigned char BITMAP_HEADER[] = { 0x42, 0x4D, 0xB6, 0x91, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x36, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x50, 0x01, 0x00, 0x00, 0xE8, 0x00, 0x00, 0x00, 0x01, 0x00, 0x18, 0x00, 0x00, 0x00, 0x00, 0x00, 0x70, 0xAD, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0xEB, 0x0A, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; printf("Bitmap header size is %d\n", (int) sizeof(BITMAP_HEADER)); int file_size = (IMG_X_SIZE1*IMG_Y_SIZE1) * 3 + sizeof(BITMAP_HEADER); // write byte 0 (LSB) BITMAP_HEADER[FILE_SIZE_OFFSET+0] = (file_size >> 0) & 0xFF; // write byte 1 BITMAP_HEADER[FILE_SIZE_OFFSET+1] = (file_size >> 8) & 0xFF; // write byte 2 BITMAP_HEADER[FILE_SIZE_OFFSET+2] = (file_size >> 16) & 0xFF; // write byte 3 (MSB) BITMAP_HEADER[FILE_SIZE_OFFSET+3] = (file_size >> 24) & 0xFF; printf("Bitmap file size: %02X %02X %02X %02X\n", BITMAP_HEADER[FILE_SIZE_OFFSET+0], BITMAP_HEADER[FILE_SIZE_OFFSET+1], BITMAP_HEADER[FILE_SIZE_OFFSET+2], BITMAP_HEADER[FILE_SIZE_OFFSET+3] ); // write byte 0 (LSB) BITMAP_HEADER[PIXEL_WIDTH_OFFSET+0] = (unsigned char)((IMG_X_SIZE1 >> 0) & 0xFF); // write byte 1 BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1] = (unsigned char)((IMG_X_SIZE1 >> 8) & 0xFF); // write byte 2 BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2] = (unsigned char)((IMG_X_SIZE1 >> 16) & 0xFF); // write byte 3 (MSB) BITMAP_HEADER[PIXEL_WIDTH_OFFSET+3] = (unsigned char)((IMG_X_SIZE1 >> 24) & 0xFF); printf("Bitmap width: %02X %02X %02X %02X\n", BITMAP_HEADER[PIXEL_WIDTH_OFFSET], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+1], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+2], BITMAP_HEADER[PIXEL_WIDTH_OFFSET+3] );
