15 years agovhdl stopwatch with LPM RAM
I am doing a lab assignment about a VHDL stopwatch. this watch can store 16 32-bits timestamp in the memory. and when readmode = '1', the stopwatch will show the timestamps. below is my code.(the other modules are working fine, only this one doesn't work yet.) could anybody tell me what is wrong with it? I really appreciate it. --- Quote Start --- LIBRARY ieee; USE ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; use ieee.numeric_std.all; entity stopwatch is port ( clk : in std_logic; readmode : in std_logic; reset : in std_logic; store : in std_logic; data_ram : in std_logic_vector(31 downto 0); data_clock : in std_logic_vector(31 downto 0); addr_user : in std_logic_vector(3 downto 0); ram_write_en: out std_logic; addr : out std_logic_vector(3 downto 0); data : out std_logic_vector(31 downto 0) ); end stopwatch; ARCHITECTURE arch_stopwatch of stopwatch is TYPE state_type IS (s0,s1,s2,s3,s4,s5,s6,s7,s8,s9,s10,s11,s12,s13,s14,s15,s16); signal state : state_type := s0; signal stage : std_logic_vector(3 downto 0); signal flag : std_logic_vector(1 downto 0); signal c_store, n_store : std_logic; signal fall_edge : std_logic; begin flag <= reset & readmode; n_store <= store; fall_edge <= c_store and ( not n_store ); process(clk, reset) begin if( reset = '1' ) then c_store <= '1'; elsif( rising_edge(clk) ) then c_store <= n_store; end if; end process; process variable r_counter : std_logic_vector(3 downto 0); begin WAIT UNTIL (clk'event and clk = '1'); if( flag = "10" or flag = "11" ) then stage <= "0000"; state <= s0; ram_write_en <= '1'; --addr <= (others => '0'); data <= (others => '0'); ------------------------reset Memory------------------------ for i in 0 to 15 loop addr <= r_counter; r_counter := r_counter + 1; end loop; ------------------------------------------------ elsif( flag = "00" ) then data <= data_clock; -------------store time--------- CASE state IS WHEN s0 => ram_write_en <= '0'; stage <= "0000"; state <= s1; when s1 => if(fall_edge = '1') then addr <= stage; ram_write_en <= '1'; stage <= stage + 1; else ram_write_en <= '0'; end if; if( stage = "1111" ) then state <= s2; else state <= s1; end if; when s2 => when others => state <= s0; END CASE; --------------------------------- elsif( flag = "01" ) then ram_write_en <= '0'; addr <= addr_user; data <= data_ram; end if; end process; end arch_stopwatch; --- Quote End ---1 Reply
First problem I see:
Your address actually increments by 16 on each clock, so the addresses in between are not written to. Also, you have included std_logic_unsigned and numeric_std. You should only use one or the other - (numeric_std is a standard package, std_logic_unsigned is not an IEEE standard). Did you have any problems other than these?------------------------reset Memory------------------------ for i in 0 to 15 loop addr <= r_counter; r_counter := r_counter + 1; end loop;
