Verilog code for serial communication protocols for cyclone 10 LP evaluation board without nios II
sir can you provide Verilog code for all serial communication protocols(UART,I2C,SPI,CAN) for cyclone 10 LP evaluation board in Quartus prime lite application without using nios II processor and with pin planner and output.
- SyafieqS
There is no template Verilog for serial communication, we used IP that is integrated in Qsys, generated to HDL.
You can use that way.
- SyafieqS
Let me know if there is any update
- SyafieqS
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
