SKell26's avatar
SKell26
6 years ago
Using the SD Card IP in Platform Designer
I currently have Quartus version 18.1 downloaded and I want to use the SD card IP core that is apart of the Altera University Program to interact with the micro SD card on my DE0 CV Development Board. Unfortunately, I do not see this IP core under University Program > Memory in the IP catalog. However, when I look in the IP folder I see the IP core. Is there a .qsys file for the SD card IP core so I can use it in the Platform Designer and if so how do I get to it?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Please allow me some time to check with the team.
    Best regadrs,
    KhaiY
    KhaiChein_Y_Intel
    Upon checking, the University Program SD Card IP core has been deprecated and removed from Quartus. It should not be used.
    KhaiY
    • SKell26's avatar
      SKell26
      What is the next best thing to do if I am unable to use this IP core? I really need this to be able to do read and writes for my micro SD card.
    KhaiChein_Y_Intel
    In this case, you have to use the older version of the software that supports this IP.
    KhaiY
    • SKell26's avatar
      SKell26
      Nope, downloading a previous version of Quartus solved this issue. Thank you for your help.
