Using Library Models tutorial question
I'm trying to follow the "Using Library Models" tutorial VHDL versions and I'm getting VHDL syntax errors trying to synthesize the code in the document. I am just copying and pasting the code, and I thought I did it correctly.
Quartus version is 20.1 lite targeting a Terasic DE-0 Nano Dev Kit.
The errors are pointing to these lines:
BEGIN
PROCESS ( Reset, Clock )
BEGIN
IF (Reset = ’1’) THEN
Areg <= (OTHERS => ’0’) ;
Breg <= (OTHERS => ’0’) ;
Zreg <= (OTHERS => ’0’) ;
SelR <= ’0’ ;
AddSubR <= ’0’ ;
Overflow <= ’0’ ;
Error (10500): VHDL syntax error at addersubtractor.vhd(39) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(39) near text ""; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(40) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(40) near text ""; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(41) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(41) near text ""; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(42) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(42) near text ""; expecting ")", or ","
Error (10500): VHDL syntax error at addersubtractor.vhd(43) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(43) near text ""; expecting ";"
Error (10500): VHDL syntax error at addersubtractor.vhd(44) near text
Error (10500): VHDL syntax error at addersubtractor.vhd(44) near text ""; expecting ";"
Error (10500): VHDL syntax error at addersubtractor.vhd(45) near text
