15 years ago
SD Card Interface with DE2 in Verilog
I am working on the DE2 development board and I have make use of an SD Card to store data (JPEG image data for the final project output). Can you kindly point me to where I should start? Materials would be nice. :)
Past inquiries in other forums suggested that I look into a file system for the SD so that I could use it in PCs. Also, mentors of mine suggest I look into the clocking diagram of an SD interface. These are overwhelming topics so I'd like to know where to start.
Thank you in advance.
    hi evry one,
    I have a similar problem.
    i use Altera university program educational board De4 and i wan't to interface my board with terasic Sd_card, I first create a sopc project and complie and download *.sof into target board, then I also create a demo NiosII project "Hello world!" but when i run it as NIOS II hardware i get this error : Downloading ELF Process failed
    and in console i read this
    using cable "usb-blaster [usb-0]",device1,instance0x00
    pausing target processor: not reponding.
    resetting and trying again: failed
    leaving target processor paused
    can any one help me please to solve this problem
    --- Quote Start ---
    hi evry one,
    --- Quote End ---
    hello there I am not able to interpret what exactly is the issue you are facing but it will be helpful if you can provide some screen shot of the console message. For your reference you can go through the video in the link below.
    https://www.youtube.com/watch?v=1a_cd6fbroa
    --- Quote Start ---
    --- Quote End ---
    Good morning,
    to start i use this tutorial video to test my FPGA using the NIOS program.
    evry thing is OK until i run the C program within the eclipse as NIOS Hardware i get this error shown in the screen shot belowhttps://alteraforum.com/forum/attachment.php?attachmentid=14115&stc=1
    it seems you have problem related to cygwin. Delete the files and try to generate the qsys component again. While generating there will be a listing in the pop up window which appears while you generate the program. In the list locate is there any error related to cygwin. If it is there then you need to update your cygwin.
    --- Quote Start ---
    --- Quote End ---
    I remove the file and regenerate the HDL but nothing related to cygwin is mentionned in the popup messages.
    I don't khnow what i have to do in my case :confused:
    hi,
    i programmer the DE4 with the IP core created by qsys tool then i used the template hello world to test the nios communication, i build with succes the project but
    while runing the program as nios hardware i get this error
    can any one help me to found a solution. thx
