9 years agoReset and tutorial Using the SDRAM on Altera's DE0-Nano Boards
The tutorial Using the SDRAM on Altera's DE0-Nano Boards uses the Clock Signals IP Core to provide a clock to the SDRAM. But I found that pressing the Key(0) was not resetting. Indeed, in altera_up_altpll.v the reset is not connected to areset of the altpll instance. Here is a correction:altpll PLL_for_DE_Series_Boards (
// Inputs
.inclk ({1'b0, refclk}),
.areset (reset),
// Outputs
.clk ({3'b0, outclk2, outclk1, outclk0}),
.locked (locked),
defparam
PLL_for_DE_Series_Boards.port_areset = "PORT_USED",
It works fine, but let me know if I overlooked something. Thanks1 Reply
- rsoff
hello,
i am trying to work with he same tutorial.
everything works fine except that the key(0) is not resetting.
i tried to use your correction but still with no success.
i noticed that in "nios_system.v" file, the reset defines as "reset_reset" and not as "reset_reset_n" as it should be:
perhapes it might be the problem.
what should i do to change it?
thanks in advance.
