9 years agoReset and tutorial Using the SDRAM on Altera's DE0-Nano Boards
Hello, The tutorial Using the SDRAM on Altera's DE0-Nano Boards uses the Clock Signals IP Core to provide a clock to the SDRAM. But I found that pressing the Key(0) was not resetting. Indee...
rsoff
7 years agohello,
i am trying to work with he same tutorial.
everything works fine except that the key(0) is not resetting.
i tried to use your correction but still with no success.
i noticed that in "nios_system.v" file, the reset defines as "reset_reset" and not as "reset_reset_n" as it should be:
perhapes it might be the problem.
what should i do to change it?
thanks in advance.
