QUARTUS ON VIRTUAL MACHINE W11 ON MAC
- SyafieqS
What internal error are you facing? Any snapshot? error message
- Sarp
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3718
Stack Trace:
0x43782: DYGR_ROUTE_TIMING_INFO::get_timing_node + 0xcc12
0x14d80: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xaf0
0x14a0c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x77c
0x143bd: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x12d
0x1a043: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x53
0x4701: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x191
0x23f69: DYGR_PLACE_INFO_BODY::load_data + 0x29
0x23f12: DYGR_PLACE_INFO::load_data + 0x52
0x2484: DYGR_DIE_INFO_BODY::load_data + 0x104
0x19686: MPP_ROOT::start + 0x5a6
0x73da: Legacy_fitter_Init + 0x636a
0x257f: Legacy_fitter_Init + 0x150f
0x2168: Legacy_fitter_Init + 0x10f8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa10xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f0xee2bb: uaw_wcsrchr + 0xe87fb
0x8520f: uaw_wcsrchr + 0x7f74f
0x1b6b27: NtWaitLowEventPair + 0x1a83e7End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
- SyafieqS
Hi Sarp,
Window 11 is not supported for Quartus 13.1. You need to use supported OS for particular version.
- Sarp
Tried on w10 vm but got the same error.
- SyafieqS
Do you mind to attach the design here for me to replicate?
Let me know any concern on this.
You can archive it to qar format.
- SyafieqS
Let me know if there is any update from previous reply
- Sarp
I tried a simple and gate diagram example with 2 inputs an and2 gate and an output. I am getting the same error while compiling other projects that works on other windows computers.
- SyafieqS
Seem to me like an env compatibility.
Using VM might sometime facing issue and is encouraged to use directly the OS installed not as virtualized.
Also, with assuming you are using new mac with native arm, this might compatibility issue for translator to x86 arc when running VM Window.
- _AK6DN_
What version of MacOS are you running?
Is this on an M-series based Mac hardware (ie, ARM processor)?
What VM software are you running?
It was mentioned in another post that QuartusII 13.1 is not guaranteed to run under Windows11.
I run QuartusII 13.0sp1 just fine on Windows10pro64b but it is not virtualized, it is on a physical Intel X86 processor.
Have you tried the WINE emulator to run Quartus on your Apple MacOS?
- SyafieqS
May I know if there is any update from previous reply?
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
