QUARTUS ON VIRTUAL MACHINE W11 ON MAC
Internal Error: Sub-system: DYGR, File: /quartus/ddb/dygr/dygr_place_info.cpp, Line: 3718
Stack Trace:
0x43782: DYGR_ROUTE_TIMING_INFO::get_timing_node + 0xcc12
0x14d80: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0xaf0
0x14a0c: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x77c
0x143bd: DYGR_BLK_PHYSICAL_IMPLEMENTATION::populate_port_info_transient_data + 0x12d
0x1a043: DYGR_PLACE_INFO_BODY::set_transient_data_members + 0x53
0x4701: DYGR_PLACE_INFO_BODY::load_data_from_pdb + 0x191
0x23f69: DYGR_PLACE_INFO_BODY::load_data + 0x29
0x23f12: DYGR_PLACE_INFO::load_data + 0x52
0x2484: DYGR_DIE_INFO_BODY::load_data + 0x104
0x19686: MPP_ROOT::start + 0x5a6
0x73da: Legacy_fitter_Init + 0x636a
0x257f: Legacy_fitter_Init + 0x150f
0x2168: Legacy_fitter_Init + 0x10f8
0xf8a6: TclInvokeStringCommand + 0xc6
0x112a8: TclEvalObjvInternal + 0x328
0x121b5: TclEvalEx + 0x8d5
0x12d48: TclEvalObjEx + 0x2d8
0x1abbd: Tcl_EvalObjCmd + 0xfd
0x56917: TclExecuteByteCode + 0xe47
0xa2376: TclObjInterpProcCore + 0x76
0x7c117: Tcl_FSEvalFileEx + 0x1d7
0x7a626: Tcl_EvalFile + 0x36
0xc1ff: qexe_ipc_progress_bar_name + 0x12bf
0x11dd6: qexe_get_command_line + 0x1556
0x150d5: qexe_run_tcl_option + 0x585
0x1e03d: qcu_run_tcl_option + 0xb8d
0x156ed: qexe_process_cmdline_arguments + 0x54d
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0xee2bb: uaw_wcsrchr + 0xe87fb
0x8520f: uaw_wcsrchr + 0x7f74f
0x1b6b27: NtWaitLowEventPair + 0x1a83e7
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
