15 years agoProblem using TRDB-D5M Camera with SOPC Builder
I'm trying to use the TRDB-D5M camera connected to a DE2-115 with the UP video design examples. However I can't achieve what the example design file contained in following folder is supposed to do:
IP_Core_Demos\Video_Demos_using_SOPC_Builder\DE2-115\Example_4_Video_In The main modifications that I made in SOPC builder is to change the input of the 'Video-In Decoder' core to THDB_D5M camera, add 'Bayer Pattern Resampler', use 'Scaler' and 'Clipper' components to match VGA 640 x 480 specifications. The system was generated successfully. Then I added the following lines to the main example_4_video_in.v file to be able to read from the camera: .PIXEL_CLK_to_the_Video_In_Decoder(PIXEL_CLK), .FRAME_VALID_to_the_Video_In_Decoder(FRAME_VALID), .LINE_VALID_to_the_Video_In_Decoder(LINE_VALID), .PIXEL_DATA_to_the_Video_In_Decoder (PIXEL_DATA), This compiled without errors too. But when I download the .sof to the board, I don't get any display on the VGA output. Am I missing something there? I can see that the 'Video-In Decoder' component has option THDB_D5M but the camera is called TRDB_D5m. Could that be a reason? The camera system CD has an example file which works fine, but it does not make use of SOPC. I would like the video source to be an SOPC component. Has anybody used this camera in this way?25 Replies
Hi Evired, Can you help me the way you config Audio and Video Config IP. I dont know how to config it!
I am able to implement the video streaming system on Qsys. The issue is, I am getting the video upside down. It seems you also faced the same issue. Are you able to resolve it. Any help will be really appreciated. - Altera_Forum
Hi, Guys.
i am working on video processing using d5m camera with de2-70. i am using qsys generation and nios 2 c code programming but i found a problem that altera does not hv pin planner pin for camera_if port. Is it a must to use verilog code to perform d5m camera set up? - Altera_Forum
Hi, Guys.
You might want to have a TRDB-D5M CMOS camera module from Terasic to plug it into your DE2 board and use the sample code they provide.
