15 years agoProblem using TRDB-D5M Camera with SOPC Builder
I'm trying to use the TRDB-D5M camera connected to a DE2-115 with the UP video design examples. However I can't achieve what the example design file contained in following folder is supposed to do: ...
10 years agoHi, Guys.
i am working on video processing using d5m camera with de2-70. i am using qsys generation and nios 2 c code programming but i found a problem that altera does not hv pin planner pin for camera_if port. Is it a must to use verilog code to perform d5m camera set up?
