ABerg28
5 years agoNo response to my plea for help: Try again
I am trying to run the NIOS II tutorial that will run the Hello World program. I tried to follow a YouTube tutorial and got stuck at the creation of the BSP step. Kept getting error messages that I d...
BoonBengT_Altera
Moderator
5 years agoHi @ABerg28,
Thank you for posting in Intel community forum and hope this message find you well.
I did managed to look into your other thread where you are facing some error on WSL.
Are you using windows OS? And do you have WSL installed?
If not would recommend to try and so do, further instruction to installed WSL can be found here.
Please do try and let us know if that works.
Warm regards.
BB
- ABerg285 years ago
Thank you for pointing this out to me. I think you've correctly identified the problem for me. However, while I appreciate the fact that you apparently solved the problem, I would have appreciated it even more if Intel had made sure that their design tools would actually work in Quartus II version 19.1 for Windows.
Arnie Berger
