Need Help Writing to SRAM
I am working on a project that is going to be an interface between a custom digital imager and a computer monitor. I have my whole set up done in the SOPC builder and some other VHDL code written to control outputs for controlling the imager.
The problem I am facing now is how to save the image data in memory? The incoming image is 60x80 pixels and I just need to save it in the SRAM memory with the initial address of 0x00080000 and the system I built in the SOPC builder should take care of the rest. The incoming pixel data will be 14 bits in size (output of a 14-bit A to D converter). I have no experience with writing to memory so if someone could help me out that would be awesome!! Thanks ahead of time!! Greg4 Replies
If you can format the incoming data as an Avalon Stream, then you could use a DMA component (such as Altera's SGDMA) to write the image to memory.
How do I do that? I am a rookie at this stuff and the only way I have been able to do what I have done is by following a demo and reading a textbook...
You can read about the Avalon Stream specification in this document (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) (chapter 5) and the Altera SGDMA in this document (http://www.altera.com/literature/ug/ug_embedded_ip.pdf) (chapter 25).
To connect your custom interface with the SGDMA in SOPC builder you will have to create a custom component. You can have a look at this document (http://www.altera.com/literature/ug/ug_sopc_builder.pdf) (chapter 6) about SOPC builder's component creator. - Altera_Forum
Ok I'll take a look at it. Thanks for the help.
