14 years agoNeed Help Writing to SRAM
I am working on a project that is going to be an interface between a custom digital imager and a computer monitor. I have my whole set up done in the SOPC builder and some other VHDL code written to ...
14 years agoYou can read about the Avalon Stream specification in this document (http://www.altera.com/literature/manual/mnl_avalon_spec.pdf) (chapter 5) and the Altera SGDMA in this document (http://www.altera.com/literature/ug/ug_embedded_ip.pdf) (chapter 25).
To connect your custom interface with the SGDMA in SOPC builder you will have to create a custom component. You can have a look at this document (http://www.altera.com/literature/ug/ug_sopc_builder.pdf) (chapter 6) about SOPC builder's component creator.
