9 years agointelFPGA Monitor Program not connecting [DE1-SoC]
I'm following the tutorial on the intelFPGA monitor program for the DE1-SoC Arm 9 core, and I'm using the sample DE1-SoC Computer program with sample program JTAG Uart demonstration. However, the board will not connect using semihosting, or any other program for that matter.
Error message reads Could not query JTAG Instance IDs.Please ensure the FPGA has been configured using the correct .sof file. It's the correct .sof file, even tried manually connecting using the GUI button to connect, still of no avail. I tried the NIOS II program and everything runs fine. Why can it not communicate? It's set to the cpu0- core and not the one that powers up in reset.5 Replies
^^Bump
Here is the error code C:/altera_lite/16.0/quartus/bin64/quartus_pgm -c "DE-SoC [USB-1]" --auto 1) DE-SoC [USB-1] 4BA00477 SOCVHPS 02D120DD 5CSE(BA5|MA5)/5CSTFD5D5/.. Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:32:00 2017 Info: Command: quartus_pgm -c "DE-SoC [USB-1]" -m jtag -o P;../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof@2 Info (213045): Using programming cable "DE-SoC [USB-1]" Info (213011): Using programming file ../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof with checksum 0x0ADD8F95 for device 5CSEMA5F31@2 Info (209060): Started Programmer operation at Tue Sep 26 12:32:02 2017 Info (209016): Configuring device index 2 Info (209017): Device 2 contains JTAG ID code 0x02D120DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Tue Sep 26 12:32:05 2017 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 284 megabytes Info: Processing ended: Tue Sep 26 12:32:05 2017 Info: Elapsed time: 00:00:05 Info: Total CPU time (on all processors): 00:00:02 ARM_A9_HPS_arm_a9_0 will be halted upon running the preloader. Skip halting. ARM_A9_HPS_arm_a9_1 will be halted upon running the preloader. Skip halting. Halting operation timed out while halting Nios2 Failed to halt Nios2 Halting operation timed out while halting Nios2_2nd_Core Failed to halt Nios2_2nd_Core Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:32:45 2017 Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2530 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0 Current hardware is: DE-SoC [USB-1] Successfully change hardware frequency to 16Mhz Found HPS at device 1 Double check JTAG chain HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Double check device identification ... >>CPU0 halted at 0x3ff82818. >>Resetting HPS. >>Downloading preloader..... >>Program loaded. PC set to program entry (0xFFFF0000) >>Setting vector base address register to: 0xffff0000 Timed out while waiting for preloader to finish Preloader failed to run. HPS components may not have been configured. Possible causes for the failure: 1. Linux SD card is inserted and Linux is running. 2. FPGA-side components are accessing HPS memory. arm-altera-eabi-gcc -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -Wall -Wl,--defsym -Wl,arm_program_mem=0x0 -Wl,--defsym -Wl,arm_available_mem_size=0x3ffffff8 -Wl,--defsym -Wl,__cs3_stack=0x3ffffff8 -T"C:/altera_lite/16.0/University_Program/Monitor_Program/build/altera-socfpga-hosted.ld" -o "C:/Users/Owner/Documents/semihosting_example.axf" "C:/Users/Owner/Documents/semihosting_example.c" ELF generated at C:/Users/Owner/Documents/semihosting_example.axf. cd C:/Users/Owner/Documents ; arm-altera-eabi-objcopy -O srec semihosting_example.axf semihosting_example.srec SREC generated at C:/Users/Owner/Documents/semihosting_example.srec. Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:35:06 2017 Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2608 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0 --source=C:/Users/Owner/Documents/semihosting_example.srec Current hardware is: DE-SoC [USB-1] Hardware frequency: 16000000 Found HPS at device 1 Double check JTAG chain HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Double check device identification ... Warning: Not able to halt CPU 0 Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Error: Failed to read r15 >>CPU0 halted at 0xfffffff8. >>Resetting HPS. Warning: Not able to halt CPU 0 >>Downloading preloader..Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Error: Fail to write 2048 of DWORD(s) to address 0xFFFF0000 through CPU 0 Error: Failed to write 2048 words to 0xffff0000. Loading SREC failed. >>Downloading user program.Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Stall Mode Error: Fail to read 1 of DWORD(s) from address 0x00000007 through CPU 0 Error: Failed to load program. Error: Sticky Error: 1 Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 117 megabytes Error: Processing ended: Tue Sep 26 12:35:21 2017 Error: Elapsed time: 00:00:15 Error: Total CPU time (on all processors): 00:00:03 - Altera_Forum
I got the exactly same error, could not solve it after trying everything I can think of.
Did you make it work eventually? - Altera_Forum
I am stuck with the same issue now. Were you able to solve this? - JJian21
I have the same issue, did you fix this problem?
Btw, I cannot find the .sof file in my testing folder, where could you find it?
