9 years agointelFPGA Monitor Program not connecting [DE1-SoC]
I'm following the tutorial on the intelFPGA monitor program for the DE1-SoC Arm 9 core, and I'm using the sample DE1-SoC Computer program with sample program JTAG Uart demonstration. However, the boa...
9 years ago^^Bump
Here is the error code C:/altera_lite/16.0/quartus/bin64/quartus_pgm -c "DE-SoC [USB-1]" --auto 1) DE-SoC [USB-1] 4BA00477 SOCVHPS 02D120DD 5CSE(BA5|MA5)/5CSTFD5D5/.. Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:32:00 2017 Info: Command: quartus_pgm -c "DE-SoC [USB-1]" -m jtag -o P;../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof@2 Info (213045): Using programming cable "DE-SoC [USB-1]" Info (213011): Using programming file ../Computer_Systems/DE1-SoC/DE1-SoC_Computer/verilog/DE1_SoC_Computer.sof with checksum 0x0ADD8F95 for device 5CSEMA5F31@2 Info (209060): Started Programmer operation at Tue Sep 26 12:32:02 2017 Info (209016): Configuring device index 2 Info (209017): Device 2 contains JTAG ID code 0x02D120DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209011): Successfully performed operation(s) Info (209061): Ended Programmer operation at Tue Sep 26 12:32:05 2017 Info: Quartus Prime Programmer was successful. 0 errors, 0 warnings Info: Peak virtual memory: 284 megabytes Info: Processing ended: Tue Sep 26 12:32:05 2017 Info: Elapsed time: 00:00:05 Info: Total CPU time (on all processors): 00:00:02 ARM_A9_HPS_arm_a9_0 will be halted upon running the preloader. Skip halting. ARM_A9_HPS_arm_a9_1 will be halted upon running the preloader. Skip halting. Halting operation timed out while halting Nios2 Failed to halt Nios2 Halting operation timed out while halting Nios2_2nd_Core Failed to halt Nios2_2nd_Core Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:32:45 2017 Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2530 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0 Current hardware is: DE-SoC [USB-1] Successfully change hardware frequency to 16Mhz Found HPS at device 1 Double check JTAG chain HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Double check device identification ... >>CPU0 halted at 0x3ff82818. >>Resetting HPS. >>Downloading preloader..... >>Program loaded. PC set to program entry (0xFFFF0000) >>Setting vector base address register to: 0xffff0000 Timed out while waiting for preloader to finish Preloader failed to run. HPS components may not have been configured. Possible causes for the failure: 1. Linux SD card is inserted and Linux is running. 2. FPGA-side components are accessing HPS memory. arm-altera-eabi-gcc -g -O1 -mfloat-abi=soft -march=armv7-a -mtune=cortex-a9 -mcpu=cortex-a9 -Wall -Wl,--defsym -Wl,arm_program_mem=0x0 -Wl,--defsym -Wl,arm_available_mem_size=0x3ffffff8 -Wl,--defsym -Wl,__cs3_stack=0x3ffffff8 -T"C:/altera_lite/16.0/University_Program/Monitor_Program/build/altera-socfpga-hosted.ld" -o "C:/Users/Owner/Documents/semihosting_example.axf" "C:/Users/Owner/Documents/semihosting_example.c" ELF generated at C:/Users/Owner/Documents/semihosting_example.axf. cd C:/Users/Owner/Documents ; arm-altera-eabi-objcopy -O srec semihosting_example.axf semihosting_example.srec SREC generated at C:/Users/Owner/Documents/semihosting_example.srec. Info: ******************************************************************* Info: Running Quartus Prime Programmer Info: Version 16.0.0 Build 211 04/27/2016 SJ Lite Edition Info: Copyright (C) 1991-2016 Altera Corporation. All rights reserved. Info: Your use of Altera Corporation's design tools, logic functions Info: and other software and tools, and its AMPP partner logic Info: functions, and any output files from any of the foregoing Info: (including device programming or simulation files), and any Info: associated documentation or information are expressly subject Info: to the terms and conditions of the Altera Program License Info: Subscription Agreement, the Altera Quartus Prime License Agreement, Info: the Altera MegaCore Function License Agreement, or other Info: applicable license agreement, including, without limitation, Info: that your use is for the sole purpose of programming logic Info: devices manufactured by Altera and sold by Altera or its Info: authorized distributors. Please refer to the applicable Info: agreement for further details. Info: Processing started: Tue Sep 26 12:35:06 2017 Info: Command: quartus_hps --cable="DE-SoC [USB-1]" -o GDBSERVER --gdbport0=2608 --preloader=C:/altera_lite/16.0/University_Program/Monitor_Program/arm_tools/u-boot-spl.srec --preloaderaddr=0xffff13a0 --source=C:/Users/Owner/Documents/semihosting_example.srec Current hardware is: DE-SoC [USB-1] Hardware frequency: 16000000 Found HPS at device 1 Double check JTAG chain HPS Device IDCODE: 0x4BA00477 AHB Port is located at port 0 APB Port is located at port 1 Double check device identification ... Warning: Not able to halt CPU 0 Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Error: Failed to read r15 >>CPU0 halted at 0xfffffff8. >>Resetting HPS. Warning: Not able to halt CPU 0 >>Downloading preloader..Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Error: Fail to write 2048 of DWORD(s) to address 0xFFFF0000 through CPU 0 Error: Failed to write 2048 words to 0xffff0000. Loading SREC failed. >>Downloading user program.Error: DBGDSCR fails to go to expected value Error: Fail to write DEBUG INSTRUCTION Error: Fail to read CPU Register Stall Mode Error: Fail to read 1 of DWORD(s) from address 0x00000007 through CPU 0 Error: Failed to load program. Error: Sticky Error: 1 Error: Quartus Prime Programmer was unsuccessful. 0 errors, 0 warnings Error: Peak virtual memory: 117 megabytes Error: Processing ended: Tue Sep 26 12:35:21 2017 Error: Elapsed time: 00:00:15 Error: Total CPU time (on all processors): 00:00:03
