GZini
6 years agoI am using 18.1 with Cyclone 5 ,I can't see the timing delays if I run timing simulation please advise
Using 18.1 lite version, all the timing simulation is identical to functional
I am using Cyclone 5 and using Univeristy waveform
- Isaac_V_Intel
Contributor
Hello Gabriel,
When you said timing delays, what are you meaning? Could you elaborate more, please.
Do you want to see the propagation delay?
Best regards
Isaac
- GZini
Hello, I mean timing simulation, I got similar results for functional and timing simulation - I am using cyclone 5 I need to know which QUARTUS free version(Lile) support timing simulaion for Cyclone 5 Regards Gabi Zini On 2020-04-28 21:40, Intel Forums wrote:
- Isaac_V_Intel
Contributor
Timing simulation is available with the lite versions as you can see at the following link [1], but with certain limitations because it is the free version.
[1] https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf?wapkw=Intel%20Software%20Standard,%20Lite,%20Pro
- Isaac_V_Intel
Contributor
Hi Gabriel,
Did the info work for your understanding?
Isaac.
