GZini
6 years agoI am using 18.1 with Cyclone 5 ,I can't see the timing delays if I run timing simulation please advise
Using 18.1 lite version, all the timing simulation is identical to functional I am using Cyclone 5 and using Univeristy waveform
Isaac_V_Intel
Contributor
6 years agoHello,
Timing simulation is available with the lite versions as you can see at the following link [1], but with certain limitations because it is the free version.
[1] https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/po/ss-quartus-comparison.pdf?wapkw=Intel%20Software%20Standard,%20Lite,%20Pro
