HPS FPGA UARTs Mapping Change
The HPS FPGA UARTs are automatic mapped in the 'build tree'- one to Linux kernel, and other to u-boot.
How do I map one UART to both?
- FawazJ_Altera
Can you elaborate more about your question?
Is this the HPS UART? Are you going to use this UART for serial terminal or data communication?
Thank you
- EFroh
There is one UART that works right on the board.
I have an Arria 10 HPS processor that communicates with different peripherals..
I want to use this UART for the u-boot and the Linux both, for CPU stdio interface (serial terminal communication).
But the UART 0 is mapped to the Linux and UART 1 is mapped to the u-boot.
I tried to enable 2 or 1 UARTs on the Pin MUX peripherals GUI , but that didn't solve the problem,
when I enabled one UART, the u-boot UART is disabled from the build tree mapping. and only Linux UART is works
Can you please help me with it?
- EFroh
- FawazJ_Altera
I presume you are using the A10 SDMMC boot, with GHRD design. In GHRD design, UART is configured with dedicated IO. You can ensure same UART node configuration in both U-Boot device tree and Linux device tree., and serial0 is specified.
Example UART node configuration at U-Boot DTS
aliases {
ethernet0 = &gmac0;
serial0 = &uart1;
i2c0 = &i2c1;
&uart1 {
u-boot,dm-pre-reloc;
status = "okay";
uart0: serial0@ffc02000 {
compatible = "snps,dw-apb-uart";
reg = <0xffc02000 0x100>;
interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&l4_sp_clk>;
resets = <&rst UART0_RESET>;
status = "disabled";
uart1: serial1@ffc02100 {
reg = <0xffc02100 0x100>;
interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
resets = <&rst UART1_RESET>;
