HPS FPGA UARTs Mapping Change
I presume you are using the A10 SDMMC boot, with GHRD design. In GHRD design, UART is configured with dedicated IO. You can ensure same UART node configuration in both U-Boot device tree and Linux device tree., and serial0 is specified.
Example UART node configuration at U-Boot DTS
aliases {
ethernet0 = &gmac0;
serial0 = &uart1;
i2c0 = &i2c1;
&uart1 {
u-boot,dm-pre-reloc;
status = "okay";
uart0: serial0@ffc02000 {
compatible = "snps,dw-apb-uart";
reg = <0xffc02000 0x100>;
interrupts = <0 110 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
clocks = <&l4_sp_clk>;
resets = <&rst UART0_RESET>;
status = "disabled";
uart1: serial1@ffc02100 {
reg = <0xffc02100 0x100>;
interrupts = <0 111 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
resets = <&rst UART1_RESET>;
