15 years agoHow to supress hierarchy optimizer for logic cells?
Hi all! :)
I'm a newbie here and in FPGA trips...:rolleyes: I'm trying to make a signal delay using AND ports and I'm having some difficult... At start, I need to delay a signal ~10ns, for that and to have good accuracy, I want to make it pass for several AND ports, that I has defined like as an entity "signal_ander" and instantiated in top-level entity as a COMPONENT. I have many instances of signal_ander chained, with SA1 output as SA2 input and so over (signal ->SA1->SA2->...->SA10)... when I synthesize that, its not work properly. In Technology Map Viewer, signal_anders are not in the same order that I define in code, it is divided in several parallel blocks chained, like: signal -> SA1 ........|-> SA2 -> SA4 -> SA7 ...................|-> SA5 ->SA9 -> SA10 ........|-> SA3 -> SA6 -> SA8 How can I force Synthesizer or Fitter (I don'k know who make this) to keep the hierarchy in code? Thanks in advance and sorry my poor english... ;) # edit# I'm using Quartus II 9.1sp2 and DE20-70 board.13 Replies
--- Quote Start --- Hi Jerry! The FPGA part number used was EP2C70F896C6. Actually, by the documentation each lcell brings about 447ps delay. I got the 4.25ns by simulation and oscilloscope :) I had change a lot of things meanwhile and finished it about July/2011. My last code for the pulse delay module is this:
This is easier to change, as if you need more or less delay per instance you just need to increase or decrease, respectively, the constant N value. The delay value will be N*lcell_delay. Hope this can be helpful :) Cheers, Mateus --- Quote End --- Dear mazzeo: thanks for you reply, it's very useful for me. for the lcell's delay value, where do you find from datasheet? i mean, can you point me which paper, which chapter?LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY pd IS PORT ( pulse :in std_logic; pulse_d :out std_logic ); end pd; architecture beha of pd is -- N gives the pulse delay multiplier. pulse_delay = N*lcell_delay -- N must be adjusted to be coherent to pulse_delay desired and lcell_delay of using device -- logic cell delay can be found in device performance documentation constant N : integer := 17; -- lcell array with N elements signal delay_line: std_logic_vector(N-1 downto 0); -- these attributes force synthesizer to keep our buffer alone :) -- this ensures that delay is the expected attribute keep: boolean; attribute keep of delay_line: signal is true; begin gen_delay: for i IN 1 TO N-1 generate delay_line(i) <= delay_line(i-1); end generate; delay_line(0) <= pulse; pulse_d <= delay_line(N-1); end beha; - Altera_Forum
Hi :)
Actually, it's not easy to find... :P You can see here: ftp://ftp.altera.com/up/pub/datasheets/de2-70/cyclone_ii/cyc2_cii5v1_01.pdf Go to page 99, Table 5–16 (LE_FF Internal Timing Microparameters) and see the last row: tLUT 447ps for 6 speed grade (the one on DE2-70). This parameter gives you the time between the input and output of a LUT. This is the lcell delay. Hope this is helpful Cheers, Mateus - Altera_Forum
--- Quote Start --- Hi :) Actually, it's not easy to find... :P You can see here: ftp://ftp.altera.com/up/pub/datasheets/de2-70/cyclone_ii/cyc2_cii5v1_01.pdf Go to page 99, Table 5–16 (LE_FF Internal Timing Microparameters) and see the last row: tLUT 447ps for 6 speed grade (the one on DE2-70). This parameter gives you the time between the input and output of a LUT. This is the lcell delay. Hope this is helpful Cheers, Mateus --- Quote End --- Thank you very much!!! it's very useful for me! but, it also doesn't provide the carry chain delay time,;)
