14 years agoHow to supress hierarchy optimizer for logic cells?
Hi all! :)
I'm a newbie here and in FPGA trips...:rolleyes: I'm trying to make a signal delay using AND ports and I'm having some difficult... At start, I need to delay a signal ~10ns, for that and to have good accuracy, I want to make it pass for several AND ports, that I has defined like as an entity "signal_ander" and instantiated in top-level entity as a COMPONENT. I have many instances of signal_ander chained, with SA1 output as SA2 input and so over (signal ->SA1->SA2->...->SA10)... when I synthesize that, its not work properly. In Technology Map Viewer, signal_anders are not in the same order that I define in code, it is divided in several parallel blocks chained, like: signal -> SA1 ........|-> SA2 -> SA4 -> SA7 ...................|-> SA5 ->SA9 -> SA10 ........|-> SA3 -> SA6 -> SA8 How can I force Synthesizer or Fitter (I don'k know who make this) to keep the hierarchy in code? Thanks in advance and sorry my poor english... ;) # edit# I'm using Quartus II 9.1sp2 and DE20-70 board.
