15 years ago
How to supress hierarchy optimizer for logic cells?
Hi all! :)
I'm a newbie here and in FPGA trips...:rolleyes:
I'm trying to make a signal delay using AND ports and I'm having some difficult...
At start, I need to delay a signal ~10ns, for that and to have good accuracy, I want to make it pass for several AND ports, that I has defined like as an entity "signal_ander" and instantiated in top-level entity as a COMPONENT.
I have many instances of signal_ander chained, with SA1 output as SA2 input and so over (signal ->SA1->SA2->...->SA10)...
when I synthesize that, its not work properly.
In Technology Map Viewer, signal_anders are not in the same order that I define in code, it is divided in several parallel blocks chained, like:
signal -> SA1
........|-> SA2 -> SA4 -> SA7
...................|-> SA5 ->SA9 -> SA10
........|-> SA3 -> SA6 -> SA8
How can I force Synthesizer or Fitter (I don'k know who make this) to keep the hierarchy in code?
Thanks in advance and sorry my poor english... ;)
# edit#
I'm using Quartus II 9.1sp2 and DE20-70 board.
    --- Quote Start ---
    Hi Jerry!
    The FPGA part number used was EP2C70F896C6.
    Actually, by the documentation each lcell brings about 447ps delay.
    I got the 4.25ns by simulation and oscilloscope :)
    I had change a lot of things meanwhile and finished it about July/2011. My last code for the pulse delay module is this:
    LIBRARY ieee;
    USE ieee.std_logic_1164.all;
    ENTITY pd IS
        PORT
            pulse     :in std_logic;
            pulse_d    :out std_logic
    end pd;
    architecture beha of pd is
    -- N gives the pulse delay multiplier. pulse_delay = N*lcell_delay
    -- N must be adjusted to be coherent to pulse_delay desired and lcell_delay of using device
    -- logic cell delay can be found in device performance documentation
        constant N : integer := 17;
    -- lcell array with N elements
        signal delay_line: std_logic_vector(N-1 downto 0);
    -- these attributes force synthesizer to keep our buffer alone :)
    -- this ensures that delay is the expected
        attribute keep: boolean;
        attribute keep of delay_line: signal is true;
        begin
        gen_delay:
        for i IN 1  TO N-1 generate
        delay_line(i) <= delay_line(i-1);
        end generate;
        delay_line(0) <= pulse;
        pulse_d <= delay_line(N-1);
    end beha;
    This is easier to change, as if you need more or less delay per instance you just need to increase or decrease, respectively, the constant N value.
    The delay value will be N*lcell_delay.
    Hope this can be helpful :)
    Cheers,
    Mateus
    --- Quote End ---
    Dear mazzeo:
    thanks for you reply, it's very useful for me.
    for the lcell's delay value, where do you find from datasheet? i mean, can you point me which paper, which chapter?
    --- Quote Start ---
    Hi :)
    Actually, it's not easy to find... :P
    You can see here: ftp://ftp.altera.com/up/pub/datasheets/de2-70/cyclone_ii/cyc2_cii5v1_01.pdf
    Go to page 99, Table 5–16 (LE_FF Internal Timing Microparameters) and see the last row:
    tLUT 447ps for 6 speed grade (the one on DE2-70).
    This parameter gives you the time between the input and output of a LUT. This is the lcell delay.
    Hope this is helpful
    Cheers,
    Mateus
    --- Quote End ---
    Thank you very much!!!
    it's very useful for me!
    but, it also doesn't provide the carry chain delay time,;)
