16 years agohey guys homework help
i have the following program which makes a finite state machine.it compiles but doesnt simulate what could be wrong?this is the code i came up with for he question
This is an exercise in using finite state machines. Part I We wish to implement a finite state machine (FSM) that recognizes two specific sequences of applied input symbols, namely four consecutive 1s or four consecutive 0s. There is an input w and an output z. Whenever w = 1 or w = 0 for four consecutive clock pulses the value of z has to be 1; otherwise, z = 0. Overlapping sequences are allowed, so that if w = 1 for five consecutive clock pulses the output z will be equal to 1 after the fourth and fifth pulses. Figure 1 illustrates the required relationship between w and z. the code module part1a(clk, in, reset, out); input clk, in, reset; output [8:0] out; reg [8:0] out; reg [8:0] state; reg count = 0; parameter zero=0, one=1, two=2, three=3,four=4,five=5,six=6,seven=7,eight=8; always @(state) begin case (state) zero: out = 9'b000000001; one: out = 9'b000000010; two: out = 9'b000000100; three: out = 9'b000001000; four: out = 9'b000010000; five: out = 9'b000100000; six: out = 9'b001000000; seven: out = 9'b010000000; eight: out = 9'b100000000; default: out = 9'b000000000; endcase end always @(posedge clk or posedge reset) begin if (reset) begin state = zero; count = 0; end else if(count==0) begin case (state) zero: if(in) begin state = one; count <= 1; end else begin state = two; count <= 1; end endcase end else if(count==1) begin case (state) one: if (in) begin state = three; count <= 1; end else begin state = two; count <= 1; end two: if(!in) begin state = four; count <= 2; end else begin state= one; count = 1; end endcase end else if (count==2) begin case (state) three: if(in) begin state = five; count = 3; end else begin state = two; count = 1; end four: if(!in) begin state = six; count = 3; end else begin state = one; count = 1; end endcase end else if(count==3) begin case (state) five: if(in) begin state = seven; count = 4; end else begin state = two; count=1; end six: if(!in) begin state = eight; count = 4; end else begin state = one; count = 1; end endcase end else if(count==4) begin case(state) seven: if(in) begin state = seven; end else begin state = two; count = 1; end eight: if(!in) begin state = eight; end else begin state = one; count <= 1; end endcase end else begin state = zero; count <= 0; end end endmodule2 Replies
If I understood correctly what you want to obtain, your code is a mess.
In particular: Why that 9bit register for a single output? You can do it with this much simpler code, involving a simple shift register.
This is only sort of template; check syntax and operation. Regardsmodule part1a(clk, in, reset, out); input clk, in, reset; output out; reg out; reg shifter; always @(posedge clk or posedge reset) begin if (reset) begin out <= 1'b0; shifter <= 4'b0101; end else begin if (shifter == 4'b0000) out <= 1'b0; else if (shifter == 4'b1111) out <= 1'b1; shifter <= { shifter , in }; end end - Altera_Forum
im new to verilog and its really confusing,thanks for the help, really appreciated
