hello, can anybody show me how to read an image from onchip memory then display on vga monitor. I am using d2-115 board. thanks
- AnandRaj_S_Intel
Attached an example of DE-2 try to go through it and implement for d2-115.
Also look into example below for d2-115 without on chip ram which can be modified.
https://www.digikey.com/eewiki/pages/viewpage.action?pageId=15925278
Anand
- rkaib
thank you AnandRs, I have looked into your document and example, but I would like something with nios 2 because I am using onchip memory that I Intialized with an image in .hex but It is not read properly from nios2 before getting displayed in the vga monitor. thanks in advance
- rkaib
I am getting this mistake message "project elf section bss is not within region onchip_memory2_0'", could you help debug it plz
- AnandRaj_S_Intel
Hi @rkaib ,
Memory overflow issue.
Increase your onchip ram(onchip_memory2_0) size in QSYS System design.
Which will solve the problem.
Anand
- AnandRaj_S_Intel
I have used onchip ram in your project, Please check attached.
Create your own eclipse project and check.
Note : Not tested
Anand
