hello, can anybody show me how to read an image from onchip memory then display on vga monitor. I am using d2-115 board. thanks
I am getting this mistake message "project elf section bss is not within region onchip_memory2_0'", could you help debug it plz
- AnandRaj_S_Intel7 years ago
Hi @rkaib ,
Memory overflow issue.
Increase your onchip ram(onchip_memory2_0) size in QSYS System design.
Which will solve the problem.
Anand
I have used onchip ram in your project, Please check attached.
Create your own eclipse project and check.
Note : Not tested
Anand
- rkaib7 years ago
thanks Anand, I have tried to increase the size but still the same problem.
could plz have quick look on it attached.
maybe I am using too much of component because I used an example from university program. I am just looking for reading the image desert.hex from the onchip memory then display in vga.
thanks
- Increase your onchip ram(onchip_memory2_0) size in QSYS System design.
- Clean the eclipse project -> generate the BSP -> build the project and check
Please upload project, Image are not giving any clue.
Anand
