Vishvas's avatar
Vishvas
5 years ago
Error while using Simulation Waveform Editor
I was trying to use the Simulation Waveform Editor but I get an error when I try to run simulation.
I have attached a screenshot of the error
Could you please help me out
Thank you
  • Hi Vishvas,
    Remove the -novopt in your script and rerun the simulation.
  • SyafieqS's avatar
    SyafieqS
    Hi Vishvas,
    • Vishvas's avatar
      Vishvas
      Thank you that issue is resolved.
      Now I'm facing a new problem. I get an error saying :
      Error (suppressible): (vsim-3601) Iteration limit 5000 reached at time 25 ns.
      I am trying to simulate a simple RS Latch. My code is below and I have attached the screenshot of the error as well. I tried searching how to resolve this error. I read this can occur when there is an infinite loop, but I'm not sure how my code can end up in such a loop. Am I doing something wrong? I'm kinda new to Quartus as well
      module part1(clk, R, S, Q);
      	input clk, R, S;
      	output Q;
      	wire R_g, S_g, Qa, Qb /* synthesis keep */;
      	and(R_g, R, clk);
      	and(S_g, S, clk);
      	nor(Qa, R_g, Qb);
      	nor(Qb, S_g, Qa);
      	assign Q = Qa;
      endmodule
