"Definitive" Terasic DE1-SoC Device Tree
Is there a Terasic released device tree for this board?
Not to my knowledge. This link has more information: https://rocketboards.org/foswiki/view/documentation/devicetreegenerator
Thanks for the reply Galfonz. I've been looking around rocketboards.org for a couple of days.
Looks like I'm going to have to do a lot of reading on device trees. - Altera_Forum
You can look at the device tree for DE1-SoC-MTL2 for a start, but this is certainly not "definitive". There is a lot peripherals on the board (for example, audio, video input) that is not included in the device tree
http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=167&no=930 - Altera_Forum
Thanks sunshine.
I found I could pull the socfpga.dtb file from the DE1_SoC_SD.img sd card image in the Linux_BSP supplied by Terasic. I figured this should be as close to 'official' as you can get as Terasic use it. - Altera_Forum
--- Quote Start --- Thanks sunshine. I found I could pull the socfpga.dtb file from the DE1_SoC_SD.img sd card image in the Linux_BSP supplied by Terasic. I figured this should be as close to 'official' as you can get as Terasic use it. --- Quote End --- Yes, and using SOCEDS you can convert the dtb to dts should you need it :) - Altera_Forum
It´s interesting that the same problem can occur i different activities. I had this problem too with Terasic released device. I followed up both the rocketboards.org link and the terasic.com link and all gbg (http://openinnovationgbg.se/) together even my problems was solved. It's a good thing with a forum.
