10 years ago"Definitive" Terasic DE1-SoC Device Tree
Is there a Terasic released device tree for this board?
10 years ago --- Quote Start --- Thanks sunshine. I found I could pull the socfpga.dtb file from the DE1_SoC_SD.img sd card image in the Linux_BSP supplied by Terasic. I figured this should be as close to 'official' as you can get as Terasic use it. --- Quote End --- Yes, and using SOCEDS you can convert the dtb to dts should you need it :)
