DE2 LCD display
I'm trying to debug a code I've written, but I'm having trouble figuring out the values of some of my parameters while using the Altera Debug Client. I'm using the Altera DE2 board and I was hoping to display some results on the LCD screen
I found in verilog this command: DE2LCDDriver(parameter) How would i convert that to C or C++?? Thanks!8 Replies
does anyone have a copy of this library?
alt_up_character_lcd.h - Altera_Forum
#ifndef __ALTERA_UP_AVALON_CHARACTER_LCD_H__
# define __ALTERA_UP_AVALON_CHARACTER_LCD_H__ # include <stddef.h> # include "sys/alt_dev.h" # include "sys/alt_alarm.h" # include "sys/alt_warning.h" # ifdef __cplusplus extern "C" { # endif /* __cplusplus */ /* * Device structure definition. Each instance of the driver uses one * of these structures to hold its associated state. */ typedef struct alt_up_character_lcd_dev { /// @brief character mode device structure /// @sa Developing Device Drivers for the HAL in Nios II Software Developer's Handbook alt_dev dev; /// @brief the base address of the device unsigned int base; } alt_up_character_lcd_dev; // system functions /** * @brief Initialize the LCD by clearing its display * * @param lcd -- struct for the LCD Controller device * **/ void alt_up_character_lcd_init(alt_up_character_lcd_dev *lcd); // file-like operation functions int alt_up_character_lcd_write_fd(alt_fd *fd, const char *ptr, unsigned int len); // direct operation functions /** * @brief Open the character LCD device specified by <em> name </em> * * @param name -- the character LCD name. For example, if the character LCD name in SOPC Builder is "character_lcd_0", then <em> name </em> should be "/dev/character_lcd_0" * * @return The corresponding device structure, or NULL if the device is not found **/ alt_up_character_lcd_dev* alt_up_character_lcd_open_dev(const char* name); /** * @brief Write the characters in the buffer pointed to by <em> ptr </em> to * the LCD, starting from where the current cursor points to * * @param lcd -- struct for the LCD Controller device * @param ptr -- the pointer to the char buffer * @param len -- the length of the char buffer * * @return 0 for success **/ int alt_up_character_lcd_write(alt_up_character_lcd_dev *lcd, const char *ptr, unsigned int len); /** * @brief Set the cursor position * * @param lcd -- struct for the LCD Controller device * @param x_pos -- x coordinate ( 0 to 15, from left to right ) * @param y_pos -- y coordinate ( 1 for the first row, 2 for the second row ) * * @return 0 for success **/ int alt_up_character_lcd_set_cursor_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos); /** * @brief Shift the cursor to left or right * * @param lcd -- struct for the LCD Controller device * @param x_right_shift_offset -- the number of spaces to shift to the right. If the offset is * negative, then the cursor shifts to the left. * * @return 0 for success **/ int alt_up_character_lcd_shift_cursor(alt_up_character_lcd_dev *lcd, int x_right_shift_offset); /** * @brief Shift the entire display to left or right * * @param lcd -- struct for the LCD Controller device * @param x_right_shift_offset -- the number of spaces to shift to the right. If the offset is * negative, then the display shifts to the left. * * @return 0 for success **/ int alt_up_character_lcd_shift_display(alt_up_character_lcd_dev *lcd, int x_right_shift_offset); /** * @brief Erase the character at the specified coordinate * * @param lcd -- struct for the LCD Controller device * @param x_pos -- x coordinate ( 0 to 15, from left to right ) * @param y_pos -- y coordinate ( 1 for the first row, 2 for the second row ) * * @return 0 for success **/ int alt_up_character_lcd_erase_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos); /* * Macros used by alt_sys_init */ # define ALTERA_UP_AVALON_CHARACTER_LCD_INSTANCE(name, device) static alt_up_character_lcd_dev device = { { ALT_LLIST_ENTRY, name##_NAME, NULL, /* open */ NULL, /* close */ NULL, /* read */ alt_up_character_lcd_write_fd, NULL, /* lseek */ NULL, /* fstat */ NULL, /* ioctl */ }, name##_BASE, } # define ALTERA_UP_AVALON_CHARACTER_LCD_INIT(name, device) { alt_up_character_lcd_init(&device); alt_dev_reg(&device.dev); } # ifdef __cplusplus } # endif /* __cplusplus */ # endif /* __ALTERA_UP_AVALON_CHARACTER_LCD_H__ */ - Altera_Forum
Hope The Above Helps....
Here I am posting some very rudimentary code that shows one way to drive the LCD display in the DE2 (very rudimentary code ....)
# include <stdio.h># include <unistd.h># include "system.h"# include "DE2_pio_regs.h"# include "altera_up_avalon_character_lcd.h" int main() { int in, out; alt_up_character_lcd_dev * lcd; int len; len =15; lcd = alt_up_character_lcd_open_dev(CHARACTER_LCD_0_NAME ); // i 've found CHARACTER_LCD_0_NAME in the system.h file alt_up_character_lcd_set_cursor_pos(lcd, 0, 1); alt_up_character_lcd_write(lcd, "SOO REALLY COOL", len); alt_up_character_lcd_set_cursor_pos (lcd, 0, 2); alt_up_character_lcd_write(lcd, "... TWICE SO ..", len); [....] } Hope this helps others.... alfa PS I am using Nios II IDE 8.0 and and Quartus/SoPC builder 8.0sp1. As I was learning how to do this i figured out that the name of some include files has changed. For instance: altera_up_avalon_character_lcd.h used to be: alt_up_character_lcd.h Has anyone else noticed? - Altera_Forum
@foleyme (http://www.alteraforum.com/forum/member.php?u=3960)
i'm trying connect keyboard to FPGA ( kit DE2 like you) and display on LCD green..can you give me verilog code of DE2LCDDriver(parameter)?I realy need it :) - Altera_Forum
you can use the LCD16207.
that will work. - Altera_Forum
hello everybody, i'm trying to display time and date on LCD ( board DE2 Altera) by VHDL code, can you help me with the code ? please, i'm a beginer. thanks you very much
I keep hitting this 'obsolete' thread... just FYI, as of Quartus 13.0sp1 the library is 'altera_avalon_lcd_16207.h'
Looking over that and the other docs should help...# include "altera_avalon_lcd_16207.h"# include "altera_avalon_lcd_16207_regs.h" then you just treat it like a 'mostly avalon' device... IORD_ALTERA_AVALON_LCD_16207_STATUS(baseAddress); IOWR_ALTERA_AVALON_LCD_16207_DATA(base, data); However... the LCD needs quite a few 'waits'... so don't try to do a lot of IOWR's in a quick sequence.. put in some waits.. try starting wtih 100usec between them to start.
