18 years agoDE2 LCD display
I'm trying to debug a code I've written, but I'm having trouble figuring out the values of some of my parameters while using the Altera Debug Client. I'm using the Altera DE2 board and I was hoping t...
18 years ago#ifndef __ALTERA_UP_AVALON_CHARACTER_LCD_H__
# define __ALTERA_UP_AVALON_CHARACTER_LCD_H__ # include <stddef.h> # include "sys/alt_dev.h" # include "sys/alt_alarm.h" # include "sys/alt_warning.h" # ifdef __cplusplus extern "C" { # endif /* __cplusplus */ /* * Device structure definition. Each instance of the driver uses one * of these structures to hold its associated state. */ typedef struct alt_up_character_lcd_dev { /// @brief character mode device structure /// @sa Developing Device Drivers for the HAL in Nios II Software Developer's Handbook alt_dev dev; /// @brief the base address of the device unsigned int base; } alt_up_character_lcd_dev; // system functions /** * @brief Initialize the LCD by clearing its display * * @param lcd -- struct for the LCD Controller device * **/ void alt_up_character_lcd_init(alt_up_character_lcd_dev *lcd); // file-like operation functions int alt_up_character_lcd_write_fd(alt_fd *fd, const char *ptr, unsigned int len); // direct operation functions /** * @brief Open the character LCD device specified by <em> name </em> * * @param name -- the character LCD name. For example, if the character LCD name in SOPC Builder is "character_lcd_0", then <em> name </em> should be "/dev/character_lcd_0" * * @return The corresponding device structure, or NULL if the device is not found **/ alt_up_character_lcd_dev* alt_up_character_lcd_open_dev(const char* name); /** * @brief Write the characters in the buffer pointed to by <em> ptr </em> to * the LCD, starting from where the current cursor points to * * @param lcd -- struct for the LCD Controller device * @param ptr -- the pointer to the char buffer * @param len -- the length of the char buffer * * @return 0 for success **/ int alt_up_character_lcd_write(alt_up_character_lcd_dev *lcd, const char *ptr, unsigned int len); /** * @brief Set the cursor position * * @param lcd -- struct for the LCD Controller device * @param x_pos -- x coordinate ( 0 to 15, from left to right ) * @param y_pos -- y coordinate ( 1 for the first row, 2 for the second row ) * * @return 0 for success **/ int alt_up_character_lcd_set_cursor_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos); /** * @brief Shift the cursor to left or right * * @param lcd -- struct for the LCD Controller device * @param x_right_shift_offset -- the number of spaces to shift to the right. If the offset is * negative, then the cursor shifts to the left. * * @return 0 for success **/ int alt_up_character_lcd_shift_cursor(alt_up_character_lcd_dev *lcd, int x_right_shift_offset); /** * @brief Shift the entire display to left or right * * @param lcd -- struct for the LCD Controller device * @param x_right_shift_offset -- the number of spaces to shift to the right. If the offset is * negative, then the display shifts to the left. * * @return 0 for success **/ int alt_up_character_lcd_shift_display(alt_up_character_lcd_dev *lcd, int x_right_shift_offset); /** * @brief Erase the character at the specified coordinate * * @param lcd -- struct for the LCD Controller device * @param x_pos -- x coordinate ( 0 to 15, from left to right ) * @param y_pos -- y coordinate ( 1 for the first row, 2 for the second row ) * * @return 0 for success **/ int alt_up_character_lcd_erase_pos(alt_up_character_lcd_dev *lcd, unsigned x_pos, unsigned y_pos); /* * Macros used by alt_sys_init */ # define ALTERA_UP_AVALON_CHARACTER_LCD_INSTANCE(name, device) static alt_up_character_lcd_dev device = { { ALT_LLIST_ENTRY, name##_NAME, NULL, /* open */ NULL, /* close */ NULL, /* read */ alt_up_character_lcd_write_fd, NULL, /* lseek */ NULL, /* fstat */ NULL, /* ioctl */ }, name##_BASE, } # define ALTERA_UP_AVALON_CHARACTER_LCD_INIT(name, device) { alt_up_character_lcd_init(&device); alt_dev_reg(&device.dev); } # ifdef __cplusplus } # endif /* __cplusplus */ # endif /* __ALTERA_UP_AVALON_CHARACTER_LCD_H__ */
