JOHI
Contributor
7 years agoDE10-Standard & DE10-nano both fail at 88% download of EPCS128.
The title is clear, this post is to share experience with the community.
I will answer it myself.
Johi
- Hi Johi, So in summary, selecting the incorrect flash devices is the root cause to the programming failure. Also, we can change TCK frequency to 6MHz for more stable programming experience. Thank You. Regards, YL
- JOHI
Contributor
As it turns out, after some searching, there is no EPCS128 but EPCS64 installed on the print.
The manuals of DE10-NANO & DE10-Standard both refer to EPCS128, replacing EPCS128 with EPCS64 fixes the problem.
Johi.
- JOHI
Contributor
Correction: DE10-Standard has effectively EPCS128 why but the remark about My nano remains valid: EPCS64 and not EPCS128.
Why the download of the DE10-Standard failed at 88 % is still unclear.
Johi
- YuanLi_S_Intel
Hi John, I am confused. So is the issue being solved? Thank You. Regards, YL - JOHI
Contributor
Hello Yl,
Yes issues were resolved:
for the DE10-nano: it is solved (configure EPCS128->EPCS64)
for the DE10-standard all of a sudden, download succeeded.
Thank you for asking.
Johi
- YuanLi_S_Intel
